Noise in reverse
1983m35a2
Noise in reverse
Post by 1983m35a2 » Sat Apr 04, 2020 7:32 pm
Is loud gear whine normal in reverse for a 450B?
I bought this machine in pieces, I rebuilt everything but, this is
The first 450 I have ran so I am not sure what to expect.
jsal
Re: Noise in reverse
Post by jsal » Sun Apr 05, 2020 3:49 am
I have a 450c mine is very noisy in reverse also not sure were to look but have using possible gear clearance
JIM
350B$Pit
Post by 350B$Pit » Mon Apr 06, 2020 7:32 am
My 350B is also noisy when in reverse...high pitch whine.
cantbeatadeere
Post by cantbeatadeere » Wed Apr 08, 2020 4:00 pm
My 350C was very loud when the reverser was in reverse....I removed the reverser and the bearing shimming was off a country mile .0014 when it should be .003 --- so around 10 thousands to loose. I put everything in spec and I must say it was WELL worth the effort.....MINT!!!
1970- JD 2520, 1991- JD 400G long track, 2003- JD 4710, 2012- JD 1026R, 2014 Bobcat E42 long arm, 2016- 14ft dump trailer, 2017- 24ft 11,000lb hyd. tilt equipment trailer aaand 2018 ram 2500 Big Horn CUMMINS :D :D
Post by Jim B » Wed Apr 08, 2020 4:05 pm
Oops! Think you meant 0.014" of play. 0.0014 would be 0.0016 too tight. :wink: Stay safe
gregjo1948
Post by gregjo1948 » Thu Apr 09, 2020 2:50 am
Thanks Jim B--- I did the math twice and thought he was backwards on the numbers.
Users browsing this forum: No registered users and 54 guests
