Is loud gear whine normal in reverse for a 450B?
I bought this machine in pieces, I rebuilt everything but, this is
The first 450 I have ran so I am not sure what to expect.
Noise in reverse
Re: Noise in reverse
I have a 450c mine is very noisy in reverse also not sure were to look but have using possible gear clearance
JIM
JIM
My 350B is also noisy when in reverse...high pitch whine.
cantbeatadeere
My 350C was very loud when the reverser was in reverse....I removed the reverser and the bearing shimming was off a country mile .0014 when it should be .003 --- so around 10 thousands to loose. I put everything in spec and I must say it was WELL worth the effort.....MINT!!!
1970- JD 2520, 1991- JD 400G long track, 2003- JD 4710, 2012- JD 1026R, 2014 Bobcat E42 long arm, 2016- 14ft dump trailer, 2017- 24ft 11,000lb hyd. tilt equipment trailer aaand 2018 ram 2500 Big Horn CUMMINS
Oops! Think you meant 0.014" of play. 0.0014 would be 0.0016 too tight.
Stay safe
Thanks Jim B--- I did the math twice and thought he was backwards on the numbers.
Users browsing this forum: No registered users and 58 guests
