I have both styles between 2 of my 3 machines.. I'm trying to decide between the 2 different adjusters.. Is there an advantage from one over the other..??
TIA for your thoughts ...
440 Track Adjusters Hydraulic vs Screw type
Chrome don't getcha Home
Re: 440 Track Adjusters Hydraulic vs Screw type
If not well maintained, manual adjusters will rust up and become useless. Other than that, personal choice.
Tks Lavoy, I'm guessing you have kits to rebuild the hydraulic style..??
Manual ones require a lot more time to adjust. And, crawling under the machine to get to the inner ones. Also keeping track of how much you move each one as you need to do both inner and outer the same. Hydraulic ones are just pump from a grease gun.
I have some pieces on hand, rest should be available.
Users browsing this forum: No registered users and 213 guests
