440 Track Adjusters Hydraulic vs Screw type
ddaxe
Post by ddaxe » Fri Sep 13, 2019 7:13 am
I have both styles between 2 of my 3 machines.. I'm trying to decide between the 2 different adjusters.. Is there an advantage from one over the other..??
TIA for your thoughts ...
Chrome don't getcha Home
Re: 440 Track Adjusters Hydraulic vs Screw type
Post by Lavoy » Fri Sep 13, 2019 8:14 am
If not well maintained, manual adjusters will rust up and become useless. Other than that, personal choice.
ddaxe
Post by ddaxe » Fri Sep 13, 2019 5:20 pm
Tks Lavoy, I'm guessing you have kits to rebuild the hydraulic style..??
Post by Stan Disbrow » Sat Sep 14, 2019 4:34 am
Manual ones require a lot more time to adjust. And, crawling under the machine to get to the inner ones. Also keeping track of how much you move each one as you need to do both inner and outer the same. Hydraulic ones are just pump from a grease gun.
Post by Lavoy » Sat Sep 14, 2019 8:31 am
I have some pieces on hand, rest should be available.
Users browsing this forum: No registered users and 196 guests
