Jd 450c oil in bellhousing
Hello had to change clutch and pressure plate on the machine. When I put the pipe that throw out bearing slides on think I went to far hit trans pump seal. Anyway it haunted me by pumping all trans fluid into bellhousing. What’s easiest way to tackle this issue?
Re: Jd 450c oil in bellhousing
Someone might have another idea but I believe you need to pull the engine back out and work to it from there; but I bet you already knew that and were just hoping for a different answer.
Jim
Jim
- gregjo1948
I agree with Jim B.
Users browsing this forum: No registered users and 265 guests
