Jd 450c oil in bellhousing
Gaylonbuch
Post by Gaylonbuch » Fri Mar 29, 2019 7:38 am
Hello had to change clutch and pressure plate on the machine. When I put the pipe that throw out bearing slides on think I went to far hit trans pump seal. Anyway it haunted me by pumping all trans fluid into bellhousing. What’s easiest way to tackle this issue?
Re: Jd 450c oil in bellhousing
Post by Jim B » Sat Mar 30, 2019 4:27 am
Someone might have another idea but I believe you need to pull the engine back out and work to it from there; but I bet you already knew that and were just hoping for a different answer.
gregjo1948
Post by gregjo1948 » Sun Mar 31, 2019 3:15 am
I agree with Jim B.
Users browsing this forum: No registered users and 115 guests
