440 ic running hot
gasmule
440 ic running hot
Post by gasmule » Sun Mar 13, 2016 8:24 am
Hello Folks,
I am new here and would like to say thanks for having me. I have a 1959 440 ic. It seems to run hot on hot days when she's pushing medium weight around (logs,brush..). She runs at 190 F now on the cold days of winter now. After it has set a few days, I do smell a bit of anti-freeze when I start up coming from the exhaust pipe. I am thinking head gasket. Am I on the right track or is it worse than I think?
Thanks,
Sam
If I got paid for my mistakes, I'd be rich!
Post by Lavoy » Sun Mar 13, 2016 11:13 am
It never hurts to check head gasket, do you have any bubbles coming in the radiator? Have you replaced the thermostat? Radiator clean both inside and outside?
gasmule
440 ic hot
Post by gasmule » Tue Mar 15, 2016 5:49 am
Thanks for the reply Lavoy. Shortly after I purchased the 440 ic, It was over heating. I found the water pump was leaking and was shot. I cleaned and flushed the radiator while I replaced the water pump and thermostat. I thought this would have solved the problem, but it still ran hot (not as hot, but still hotter then norm.)
It has boiled over when it overheated, but I think you telling me to look for bubbles when it is running before it gets hot, and I will.
Thank you,
Sam
Post by Lavoy » Tue Mar 15, 2016 8:01 am
Yeah, then that is odd. Although radiator could still be bad. What I do on my own stuff, or anything I restore, I put in the updated 6 blade fan, you can't believe how much more air they move.
gasmule
Post by gasmule » Wed Mar 16, 2016 8:23 am
I will try a six blade fan.
Thanks,
Sam
gasmule
440 ic running hot
Post by gasmule » Wed Apr 06, 2016 8:23 am
Hey Lavoy,
Turns out my radiator core was bad. Had it recored and I put a 6 blade fan on it while I was at it. We had some warm weather up here, so I tested it out. Ran at right about 190 under load all day. Thanks for the advice.
Sam :)
Post by Lavoy » Wed Apr 06, 2016 8:50 am
No problem, glad it you got it figured out.
Users browsing this forum: No registered users and 278 guests
