Lavoy, have yet another question for you concerning the 1010 we have here with a series 10 winch on it. In the service manual it shows a filler whole to add SAE 80 oil to the powershaft if it is low.The parts manual show 2 seals in this powershaft. My question is this, since there is a filler whole for the powershaft to add oil to if it is low, then the transmission fluid should not be leaking out the rear seal if the inside seal is good.Is this correct or is that seal for another purpose? I know the rear one needs replacing since I can see it leak.
Thanks, Dan
Powershaft seals
Users browsing this forum: No registered users and 41 guests
