Powershaft seals
GraderDan
Powershaft seals
Post by GraderDan » Fri May 06, 2005 2:41 pm
Lavoy, have yet another question for you concerning the 1010 we have here with a series 10 winch on it. In the service manual it shows a filler whole to add SAE 80 oil to the powershaft if it is low.The parts manual show 2 seals in this powershaft. My question is this, since there is a filler whole for the powershaft to add oil to if it is low, then the transmission fluid should not be leaking out the rear seal if the inside seal is good.Is this correct or is that seal for another purpose? I know the rear one needs replacing since I can see it leak.
Thanks, Dan
Post by Lavoy » Fri May 06, 2005 3:06 pm
Never worked on that style winch, going to have to plead ignorance for now.
Users browsing this forum: Google Adsense [Bot] and 32 guests
