Clydeman
Post
by Clydeman » Thu Sep 17, 2015 3:42 pm
HI- new member here - i'm still trying to figure out how to post - here goes again
I recently purchased a jd440ICD. An outside blade, outside mounting support arm, brackets and cylinders came with it. It also has the hydraulics and mounting arms installed for the inside blade(just lacking blade). I have located an inside blade from a jd1010 crawler. Does anyone know if these blades are interchangeable?
Thanx for any info
- Site Admin
Post
by Lavoy » Fri Sep 18, 2015 8:21 am
I did it on mine, the only real problem I have is it lifts too high and will hit the front casting so you have to be careful there.
Owner and moderator
www.jdcrawlers.com
Clydeman
Post
by Clydeman » Fri Sep 18, 2015 9:19 am
Thanks Lavoy for the response
I never considered that. My 440 came with the nose cowl and hood not mounted, so I didn't think about clearances and range of operation.
Users browsing this forum: Google Adsense [Bot] and 263 guests
