2010 early model snap ring and expansion pins
Hey im new to the forum. Doing steering clutch on a early 2010 . Question is wen I took a part I noticed that the special set screw , expansion pins and snap ring for the shaft were not there. I cant find them for sale and was wondering if anyone has had this problem.deere dident have them ... looks like the person before dident reinstall them .. any advice would be helpful. Thanks
It may have been changed to the later style ....is there a snap ring (about 5 inch) on the outside of the center hub (the one the clutches ride on)?... One of my 2010s has early on one side late on the other
I ordered a pressure plate and a few things from lavoy. Wen it comes in I will try to put it back together without set screw and expansion pins . I found a snap ring that fits so I will just put that on and see what happens .. does anyone know the purpose of the pins and special set screw?. Will just the snap ring work
Just a snap ring wont work ..the expansion ring locates the center hub ...the later ones use a snap ring on the outside of the hub and it is placed between the first and second fiber ...It is very hard to believe that you dont have one or the other as without something to locate the hub it will float out and get out into the pressure plate and lose half the fibers ........ Check your hub for a groove on the outside .....also you could get the later snap ring and have a groove cut in the hub.....PS check your message box .....Good luck Richard
On any page of the site, at the top right, are a series of radio buttons to click on: Messages, Profile, Faq, Search and Logout.
Click on the Message one and it will take you to your messages.
Users browsing this forum: No registered users and 318 guests
