1010 crawler loader fresh in for parts
Post by Lavoy » Fri Nov 23, 2007 5:47 pm
Just brought in an early 1010 gas crawler loader for parts if anyone is looking for 1010 parts. Engine ran but was weak, reverser and trans seemed to be fine. No tracks or sprockets, final drive cases are trashed, might be internals. It will be suffering a tragic death this coming week, let me know if there is anything you are looking for, I will take it off.
1010 parts
Post by mini kahuna » Fri Nov 23, 2007 6:20 pm
Lavoy I would be interested in the front pump driveshaft and coupling,my machine is a diesel,I have a cesna pump,are the parts the same?
while on the subject,can you get cylinder packings,one bucket cylinder needs a seal kit,and the dealer is a real.... rather not go to him.
1010 loader
Post by wwattson » Fri Nov 23, 2007 8:05 pm
Being a loader I'm assuming that it has 5 roller track frames. I'm still looking for one piece of steel for the front inside of the right side track frame or a complete 4 roller right side track frame. Thanks.
BKahler
Post by BKahler » Sat Nov 24, 2007 7:42 am
Lavoy, any chance the radiator would be the same as a 440ICD ?
Thanks,
Brad
Post by Lavoy » Sat Nov 24, 2007 12:56 pm
MK,
Pump parts should be the same gas or diesel, but will be serial number specific, this is an early machine.
Brad,
No, radiator is different, sorry.
Bill,
It is a 5 roller, so trackframes are different. If they are bad, I can cut you the piece you need.
Post by Lavoy » Wed Dec 05, 2007 8:03 pm
Okay, it is dead, let me know if any of you still need anything.
ron in coudy
Post by ron in coudy » Thu Dec 06, 2007 6:16 pm
lavoy I need the shift lever and shift cage. the one on the 1010 I just got is missing, the lever is canabalized
Post by wwattson » Thu Dec 06, 2007 8:21 pm
Lavoy, did this one have the dash mounted hydraulic levers? I'm still looking for one lever if it did.
Post by Lavoy » Thu Dec 06, 2007 10:16 pm
Ron,
This crawler was an early one with the dash shift, not floor shift, which do you need?
Bill,
No, loader crawler has no dash hyd pieces, I thought of you earlier, then remembered it was a loader.
shinnery
Post by shinnery » Fri Dec 07, 2007 2:35 am
Will that 1010 Reverser fit a 440ICD? Don't have the S/N handy but it has the late style throttle. Or maybe the guts fit in my housing? Bryce
Post by Lavoy » Fri Dec 07, 2007 9:42 am
Nope, completely different setup, weigs two to three times what a 440 reverser does.
ron in coudy
Post by ron in coudy » Fri Dec 07, 2007 2:46 pm
mines a 63, floor shift
thanks, Ron
Post by Lavoy » Fri Dec 07, 2007 9:22 pm
Ron,
This one won't do you any good, sorry.
ron in coudy
Post by ron in coudy » Sat Dec 08, 2007 9:58 am
that's ok, keep me in mind, I'll keep looking. Thanks, Ron
