final drive install
final drive install
what have you guys been doing to keep the brake band from cocking and hanging up on the pin? i fought with it last night then finally got it square on the drum buy working it with some rods and sliding the drive on dawls. is there something that i missed?
Brake band in the way
NNAATZ,
I think I know what you're talking about here.... If you mean a 420C...
I had some trouble to slide the re-assembled final drive and housing back into place because the brake-band kept cocking on the drum.
I loosened the brake as much as possible. I paid special attention to the load-leveler on the engine hoist (from which the final drive hung). Once I got the final drive assembly balanced and level, I could sneak it inside the brake band without it cocking.. (much... still had to reach in from the top opening with a catspaw to push the band back into place on the drum.)
Emmett
Emmett
420C Crawler 1957 w/ blade & army 6x6 winch
Users browsing this forum: No registered users and 408 guests
