Hydraulic pump
country53
Hydraulic pump
Post by country53 » Thu Aug 25, 2005 6:12 am
I've read on this forum about people installing extra hydraulic pumps on JD 420. Where does one mount it and where does one get it? What volume and pressure does a 420 have?
Post by Stan Disbrow » Thu Aug 25, 2005 8:22 am
The only place to mount an auxillary pump on a 420 that I can readily think of is on the PTO shaft. Some of the 440 wheel tractors I've seen used this method for running loaders and backhoes (using the stock pump for power steering). I can't recall ever seeing this done on a crawler, though.
Post by Lavoy » Thu Aug 25, 2005 9:16 am
Camshaft driven pump is about 8GPM at 1000PSI, crankshaft pump will do 15GPM, at up to 1500PSI give or take.
country53
hydraulic pump
Post by country53 » Thu Aug 25, 2005 10:04 am
There is a bolt pattern on the peice that holds the radiator that looks like where I would mount the pump is this correct? Where would I find a pump?
Post by Lavoy » Thu Aug 25, 2005 3:06 pm
If you have the two piece fron casting, then you could install a crankshaft driven pump. You would need the pump, mount, drive shaft, and coupler for the engine. Then you would need a large volume reservoir, and a high flow hydraulic valve.
What is it you are trying to do?
country53
hydraulic pump
Post by country53 » Fri Aug 26, 2005 5:00 am
I have a 8000# lift capacity mast for a fork truck. I saw a crawler on the web site with a mast on it and decided it would be a good winter time project. I know the fork truck had a 18GPM pump so I wanted to get things sized right. The engine doesn't run enough RPM for the industrial pumps I have access to. I am in planning stages now.
Post by Lavoy » Fri Aug 26, 2005 8:03 am
An original loader pump will do close to that GPM, but at about 1500PSI, so that may not be enough. It really shouldn't be hard to find a pump that will do 18GPM at 1850PRM and at higher pressure. It would be even better if you could find one that would bolt up to the original mounting plate.
Users browsing this forum: Google Adsense [Bot] and 46 guests
