450c steering clutch overflowing
76450c
Post by 76450c » Sun Mar 22, 2026 12:36 pm
Have a 76 450c, took it down to change final drive and now the opposite steering clutch is filling up and not draining back into transmission fast enough for it to build pressure. it is common sump and has never had this problem. so when i check trans it shows empty but left steering clutch is full to the top! Any ideas?
LeonardL
Re: 450c steering clutch overflowing
Post by LeonardL » Wed Mar 25, 2026 1:58 pm
So I always fill these through the transmission and the clutch housings. I'm thinking if you just wait a bit it will eventually settle into the other cavities. I divide the oil into thirds and that way it seems to settle in quicker.
76450c
Post by 76450c » Thu Mar 26, 2026 6:46 pm
i tried using shell oil with the same spec, come to find out the drum was mislabled, put hyguard back no more problems..
Post by Stan Disbrow » Sat Mar 28, 2026 7:17 am
Ah. That would explain a lot!
76450c
Post by 76450c » Sat Mar 28, 2026 8:00 pm
Now that the trans pressure is back to 160ish I cant get the right track to work. Worked fine before taking final drive off and all linkages to rebushing, with trans guage when i pull back left steering lever guage jumps about 50 p.s.i., pull right steering handle back it jumps maybe 4-5 psi. When I pulled off both steering covers at swap they seemed fine, hoses in each common sump seemed normal. Left steering clutch works fine, right you pull back and nothing.
76450c
Post by 76450c » Sun Mar 29, 2026 5:23 pm
Looked through whole manual many of times, I think I’ve figured it out without it. The linkage that holds the adjusting nut on the brake band is all the way down on the bottom of the pin, so when you pull up it doesn’t turn the brake linkage. At idea how to get the slack out of it? Read hundreds of forums and manual and nothing
76450c
Post by 76450c » Sun Mar 29, 2026 9:22 pm
The brake band came off the clips of it helps anybody, guess when I was putting steering clutch back on!
Post by Jim B » Mon Mar 30, 2026 5:23 am
Thanks for telling what you found. Having the solution posted always helps.
