Pull type box scraper and 350b
cjman1977
Post by cjman1977 » Mon Feb 23, 2026 9:43 pm
Could anyone comment on using a 10-ft box scraper behind a John Deere 350B loader. I don't want to overload the crawler. But at the same time, if I can go to a 12' box scraper I would like too. At the same time if I need to go down to an 8 ft I would do that. I'll be using it mostly in loose soil where the stumps have been dug up. I also have the aux hydraulic couplers installed for the lift wheels.
Any advice would be very much appreciated.
8' 10'. Or 12' what should I buy?
Bennett
JD 350B w/ 4 in1
JD 1025R Sub Compact
CAT 259D3 high flow with Mastodon mulcher head; CAT BRX 318 bush hog
Cat 304 Mini Ex with Bushmaster Brush Cutter and 28" Torrent mulcher
Soilmover Dirt Pan
LeonardL
Re: Pull type box scraper and 350b
Post by LeonardL » Sat Feb 28, 2026 3:53 pm
I'm not sure exactly what you are wanting to do. Is this like a three point box blade you pull behind an Ag tractor? The first thing you need to consider is, your 350 is only 42 to 46 horse power on a good day. If this is a box blade then I wouldn't want one any wider than about six feet. Some of these other guys may have a different opinion but that's what I would look at.
Post by Lavoy » Sun Mar 01, 2026 5:04 pm
I've pulled an 8' behind 2 cylinder crawlers a great deal, in both snow and dirt with no problem. 350 will pull a 10 foot easily. As far as a 12 foot, probably same song, just depends on how fast you want to pull, and how much dirt you want to carry.
