shift pattern for jd 440
dondeere
Post by dondeere » Mon May 14, 2012 8:14 pm
I have a 5 speed trans in my 60 440 crawler, the seller told me the shift pattern but I don't think he was correct, what is the correct shift pattern, I see several knobs with different patterns, reverse I know but the rest not so sure, is first the opposite of reverse or is first in the center?
shinnery
Post by shinnery » Mon May 14, 2012 10:31 pm
Without going out and looking at one of mine, the Operators Manual shows, top left to right 2-1-4 and bottom left to right R-5-3. So 2 is opposite R and 1 is in the center top. HTH
dondeere
Post by dondeere » Tue May 15, 2012 5:35 am
that is what I thought, the previous owner told me it was 1-2-4
R-3-5
it just did not seem right, I see alot of shift knobs for sale on ebay and the shift patterns were not the same. Makes sense. thanks.
2-1-4
R-5-3 is this correct then? seems weird.
Post by Lavoy » Tue May 15, 2012 7:51 am
I think there might be a difference on late crawlers, but can't remember.
whiteclipse16
Post by whiteclipse16 » Tue May 15, 2012 11:49 am
Glad you mentioned that Lavoy. If I remember right, my service manual has something like 2nd and Reverse switched. I was pretty confused when I put it back together but somewhere I learned that there are two variations. I think it depends on the type of gear that is on the shaft that drives the pto.
Ben
82Maple
Re: shift pattern for jd 440
Post by 82Maple » Mon Nov 24, 2025 11:45 am
Glad to find this thread.
I'm refurbishing a pair of '59 440's - one bucket and one dozer.
Both of them have the pattern:
Top R-1-4
Bottom 2-5-3
I've combed through my service manual and can find zero reference to the shift pattern.
Both came with knobs that have the Reverse and 2nd gear switched from what I posted above.
I was struggling to understand what is going on . . .
Love this message board and the scope of the content.
jimmydiesel
Post by jimmydiesel » Mon Nov 24, 2025 7:17 pm
Knob on the top is on a 59 440ICD
Knob on the bottom is from a late 60 440ICD.
Bottom line is if you put it in 2nd and it goes in reverse it has the wrong knob.
440 ICD 602 Blade 3Pt.hitch.
440 ICD 831 Loader
440IC 831 Loader
1010c Diesel 612 6 Way Blade
pop pop
Post by pop pop » Thu Dec 04, 2025 12:13 am
i was looking in a 1967 parts book and they described the two variations of 5 speed shift knobs as, (and only costing $1.50) :)
the one with the R in upper position was for the 440 ICD's, p/n T11256T.
the one with the R in lower position was for the 440 I, IC, ID , p/n M4338T.
then if you had a 1010, there were 4 variations, real confusing but was based on serial no. :(
Post by Lavoy » Sat Dec 06, 2025 10:09 am
The one at the top of the pic is for all 440's with the transmission that has the dipstick on the top, or if you prefer, all 440 crawlers, gas and diesel built after 448,000.
Users browsing this forum: No registered users and 60 guests
