420C PTO Issues
JDCrawlerdog3
420C PTO Issues
Post by JDCrawlerdog3 » Sat May 03, 2025 8:38 pm
I have a 420c with a Gearmatic 8A winch I use for logging. Towards the end of the winter I heard a noise that I thought was coming from the winch. I removed the winch and the adaptor plate, and didn't find any issues with the winch. Next check was the PTO/power shaft. The shaft "growls" when rotated, and the shaft has some end play, both in and out and up and down. Hard to see much past the differential.
I know that the PTO on 420/430 tractors was a weak link (brush hogs/tree stumps), but not sure the PTO assembly is the same used in the crawlers. I have not worked on a 420 crawler transmission before. Does the trans need need to be removed to access the PTO/power shaft assembly/bearings?
Anyone have history/experience/thoughts?
Thank you
Andrew
Last edited by JDCrawlerdog3 on Sun May 04, 2025 11:19 am, edited 2 times in total.
gus
Re: 420C PTO Issues
Post by gus » Sat May 03, 2025 9:09 pm
Not sure where your damage is. The PTO is a simple bolt on part. My tractor had a flat plate there, removed it and bolted on the pto. I would suggest just removing it to see whether there's and transmission damage or it's totally in the PTO. Complete bearing failure??
JDCrawlerdog3
Re: 420C PTO Issues
Post by JDCrawlerdog3 » Sun May 04, 2025 5:49 am
Gus,
Thanks. I think the problem is PTO power shaft assembly within the transmission. When using a winch on a crawler, the PTO attachment, like on your tractor, and the end plate that covers the differential are removed. An adaptor plate is bolted to the rear of the crawler, with a coupler that connects to the PTO shaft that is within the differential case. The winch is bolted to the adaptor. The PTO shaft turns a gear that is mounted in the adaptor plate, which in-turn drives a gear at the back of the winch.
Andrew
gus
Re: 420C PTO Issues
Post by gus » Sun May 04, 2025 8:09 pm
Can you see that if you pull the top cover?
Re: 420C PTO Issues
Post by Lavoy » Mon May 05, 2025 7:13 am
PTO shaft (not attachment) is a preload shaft, so if there is any play, the bearings are bad. Unfortunately, it's a complete tear down to fix, but running it like that is going to damage a lot of other stuff eventually.
JDCrawlerdog3
Re: 420C PTO Issues
Post by JDCrawlerdog3 » Mon May 05, 2025 10:05 am
Thought so. 2nd gear is howling too - teardown time.
Thanks.
Andrew
