Single or Double hydraulic system?
- jdcollector
- jdcollector
Re: Single or Double hydraulic system?
great to find an old post dealing with the same issues I am currently looking at now that i have the rebuilt tracks back on the machine
1) looking at details to install a rock shaft assembly/3 point and deluxe seat- great info in this post- any other thoughts or experiences are appreciated
2) I have the same challenges regarding dual valves for the 3 point and a blade. I have been "collecting" parts for a number of years. I have a total of 3 valve assemblies plus a second handle and the valve end plate needed for remote mounting a dual valve assembly. I also have the bracket for mounting the single lever handle on the rock shaft assembly. Should I use the standard approach on the fender or stack the valves on the tank as shown in the picture in this posting string? Does the dual handle configuration work in this location?
Does anyone have dimensions/availability of the shorter control rods if I mount a dual assembly on the fender?
Suggestions/recommendations appreciated
Mike
Mike
Stacking is not factory, and no factory linkages or lever exist to do so, you will have to fabricate most of it. Sideways on the fender is the only configuration for dual hydraulics that is factory.
It will work, that is not an issue, it is just whatever your preference is.
Regards valve controls etc...my engine should be ready this week or maybe next..once i get it back i will find out just what my hydraulic system will need to get it to work....so far i have not had a chance to even see...it is NLA and is front loader w/scarifier which actually is mechanical and NOT hydraulic...may need all if non functional, anyone with functional available advise. Is 2 handle version appears 1 for bucket and other for lift, i assume.
Thank You,
Dtoots1
Thank You,
Dtoots1
Browsing Marketplace I found a JD crawler for sale and one of the pictures were of the 4 spool fender mount valve, thought I would share.
Cubby267
1956 420C #80122
Cub Cadet collector;
100, 102, 104, 147 & 1200
1956 420C #80122
Users browsing this forum: jimmydiesel and 26 guests
