tips on changing reverser fluid & filter on 1010c diesel
newwood
Post by newwood » Sat Jun 03, 2023 11:16 am
My reverser is working great so I'm a little reluctant to even mess with it, but it has been over 30 years since the reverser fluid was changed and I only recently discovered that there's also a filter involved. I looked through the archives but didn't find any posts -- are there any pitfalls to changing the fluid and filter on this thing (other than pouring 3 gallons of trans/hyd fluid into a very small hole and figuring out where exactly that filter actually is located)? I'm trying to follow the old dictum: first, do no harm (which I frequently seem to violate when working on this machine).
Newwood
1010C diesel
Chapel Hill NC and Merrill WI
Hurlbutt
Re: tips on changing reverser fluid & filter on 1010c diesel
Post by Hurlbutt » Sat Jun 03, 2023 8:27 pm
Many years ago I worked with a guy in a manufacturing facility testing lab that would get excited when the oil change for his car was due. He loved doing maintenance! A common phrase he would say in near disgust concerning the way most maintain their stuff: "Oil, isn't that something they put in at the factory?"
In later years I was in the Technical Service Department where service publications originated. Manufacturers invest in testing and development at considerable expense. The specs they provide normally have sound basis.
Oil does wear out and condensation is absorbed impacting lubrication and corrosion control properties.
Best practice would be closely follow what the manual provides if possible.
Bill
Post by Lavoy » Sat Jun 03, 2023 8:42 pm
The most significant harm you can do to these crawlers is ignore required maintenance.
newwood
Post by newwood » Sun Jun 04, 2023 9:19 am
Mainly I was wondering whether the recommendations for kerosine/diesel rinse after draining is worthwhile (and if so is this before or after filter replacement) and whether there are any cautions on old filter removal/replacement (other than to make sure to put it back together in the right order and not crush the new filter by overtightening). Despite the long years, the actual hours of use are quite short, but I'm trying to make my way through all the various recommended maintenance. I've just gotten a little guy shy after fuel filter replacement and unexpected challenges with bleeding some troublesome air bubbles. So I've learned to look to the archives first.
Newwood
1010C diesel
Post by Lavoy » Mon Jun 05, 2023 8:45 am
IF the fluid appears otherwise decent, I probably wouldn't flush it. IF it has not been changed since new, I would be inclined to use it for a time period and change it again.
Users browsing this forum: No registered users and 32 guests
