What trannies are the same as the 450b?
I'm also looking for videos on their adjustment. They seem a little scarce on the 4650b.
thanks for the help
trannys
make do homesteader
pearljam724
Re: trannys
Are you referring to adjusting the clutch, brake bands or steering clutches ? This is the only video out there that I have found referring to any adjustments. A lot of times people in here will gladly help you with basic questions. For learning how to make any adjustments you’re going to have to splurge on a service manual.
https://youtu.be/KlIWuDFcPa4
Re: trannys
I don't think you are going to find many, if any, videos of adjusting the transmission. As pearljam724 post I think you need the correct technical manual for your machine (TM1033 for a 450B). You will need to study it and get the gauges required to test the pressures. Like adjusting steering clutches and brakes, every step needs to be done in the order written.
