Are most track pins generic? not as far as clip in type or press in type but as far as size or are they particular to each brand make of track? Watt i have is a press in type and is pretty bad off . Watts the best way to find a replacement ? Watt should i look for and were ? Maybe watt i am trying to ask is there a good web cite that carry's parts ? I searched through the post i didn't find anything pertaining to this . Not saying i couldn't be looking in the right spot .
i have JD 350 1968
Track master pin
Re: Track master pin
No such thing as a generic master pin, they are model and brand specific. I normally stock 350 master pins, there are headed master pins and drive type, would need to know which you have.
One could only hope! Ill be in touch thanks !
