button head grease gun couplers
Bret4207
Post by Bret4207 » Fri Jun 03, 2022 7:00 am
Anyone care to recommend a good coupler for the button head fittings on my 1010? The one I got from my Deere dealer is too big to fit some fittings. Before I take the lathe to it, I thought I might see if there's a pre-made alternative someone knows for sure will work.
40C, 420C, 1010C-L-BH, Cat D4
original possum
Re: button head grease gun couplers
Post by original possum » Sat Jun 04, 2022 9:29 am
Button head fittings come in different sizes. Don't recall exactly but believe they should be 5/8" on your 1010. Alemite brand comes to mind and should be available at auto parts stores, particularly in rural areas.
Post by Jim B » Sat Jun 04, 2022 10:55 am
I believe Lavoy has said before that he stocks them and the fittings.
Bret4207
Post by Bret4207 » Sun Jun 05, 2022 8:04 am
Thanks, maybe Lavoy will chime in.
Post by Lavoy » Sun Jun 05, 2022 9:07 am
I have used the Deere one, never had a problem, so not sure what could be the issue.
gus
Post by gus » Sun Jun 05, 2022 9:39 am
Sounds like you might have a mix of sizes. Someone replaced a few but not all.
Post by Stan Disbrow » Mon Jun 06, 2022 4:43 am
Only place on my 420c and 350C where it won't go on are the upper idlers. And that is by design. Because you have to remove a bolt to vent it. So they have these ridges to ensure you remove that bolt. Every other fitting works if I slide it on from the proper direction.
I have never had a 1010 but can't imagine there is something different
Stan.
Bret4207
Post by Bret4207 » Mon Jun 06, 2022 6:43 am
That's the problem Stan- the upper idler. I have no bolt to remove, the face is just too big to slide into the cast boss and fit.
Lavoy, I got what the local dealer had, I'm not sure it's meant for the 1010, could be for a 450 for all I know.
Post by Lavoy » Mon Jun 06, 2022 7:40 am
There has to be bolt to remove, that is what holds the cap on.
Post by Stan Disbrow » Tue Jun 07, 2022 4:46 am
Perhaps the bolt is packed with dirt and grease and you just can't see it. The grease gun head and the idler cap are made so you can't get it onto the button unless you first remove that one bolt. It has to be removed to provide a vent or pumping in grease will blow out the seal.
So machining the grease gun head to force a fit will cause problems.
Bret4207
Post by Bret4207 » Tue Jun 07, 2022 6:35 am
Okay, now I understand what you mean. I thought you meant there was a bolt in place of the button head fitting. The particular coupler I've got still won't fit the slot between the bosses. I'm going to have to chuck it up and cut some relief into the coupler.
Thanks.
Users browsing this forum: Google Adsense [Bot] and 22 guests
