40/420 head
40/420 head
Pretty sure I've got a cracked head on the 420. Had the same thing on the 40. Is this a fairly common issue? Seems odd lightning would strike twice for me.
40C, 420C, 1010C-L-BH, Cat D4
Re: 40/420 head
Common in my experience. Original? head on my 40 cracked, replacement head from an M cracked and the original head on my son-in-laws MT cracked. 2 were repairable by the local machine shop, the 3rd one suffered a catastrophic break. As you probably know new ones are usually available. Check with Lavoy, he can probably supply or source one for you if yours is not repairable.
Re: 40/420 head
Well I was wrong. I can't find a crack in the head anywhere. Not that I can see with the nekked eyeball anyway. What I did find is that the seat for the exhaust valve on #2 is non-existent! There is nothing but a faint suggestion of a partial ring where the valve seat should have been, but that's it. I've never seen anything quite like it. I also found out I appear to have 2 .045 oversized pistons, or so they are marked, and one (#2) which has some evidence of metal being caught between piston top and head. I honestly don't know how it ran as good as it did. Got a rebuilt head enroute and I'll be ordering a few more parts too.
I'll eventually take this head to the shop and have it checked and rebuilt if possible.
Amazing!
Amazing!
Re: 40/420 head
Disaster averted. Thanks for letting us know the outcome.
Re: 40/420 head
Same happened to me, just stopped being able to start it one day. Machine shop put new valve seat inserts in.
40 and older didn't have a water pump and were prone to overheating, but I didn't think cracked heads were common on a 420.
Users browsing this forum: No registered users and 32 guests
