I just bought a 1978 350C with a 6-way blade. I bought it with the understanding that it needed a lift pump. I replaced the lift pump as well as the fuel filter. The engine would only run a few seconds and die off. I decided to change the solenoid in the injection pump. I did this today, at first the engine ran for several minutes but then died. I have good fuel flow to the pump and from the return line. Now I'm back to the original problem it starts for a few seconds and shuts off. I tried running without the fuel cap to address a venting issue but have the same results. I'm not a gear head so bear with me but try to do basic repairs and maintenance on my own.
All ideas will be appreciated.
JD350-C running issues
JD350-C 6 way dozer, JD 5400, JD1025E
Re: JD350-C running issues
Sounds like you may have an injection pump problem. Search “mouse turds” on this site.
Best regards, Bruce
Best regards, Bruce
