JD 450
bearchopper
JD 450
Post by bearchopper » Fri Sep 03, 2021 2:28 pm
I am a new member and I need you assistance,I bought a JD450 last month which runs well.I would like to know what year it is serial n5e3m011711t also is it a JD450 b or a JD450.I have another question my bottom rollers have buttonholes for greasing and they are all blocked so I unscrewed them and with my needle greaser I applied grease 0 grade and reinstalled them what came out was like black oil .Thanks Bearchopper
Re: JD 450
Post by Lavoy » Fri Sep 03, 2021 3:10 pm
Most likely sealed lifetime bottom rollers, they would be oil filled.
Re: JD 450
Post by Jim B » Fri Sep 03, 2021 3:26 pm
Welcome.
Your serial number tag should be more like SNT5E3M011711T.
SN = serial number
T = Tractor
5 = JD450
E+ Crawler Loader
3 = Diesel Engine
M = Hi-Low-Reverse transmission
011711 = 1965 built crawler
T = built at Dubuque John Deere Tractor Works
So you have a 1965 450 Diesel Crawler Loader with the HLR. On the FAQ board here there is a post by Stan Disbrow that lists machines and the proper number JD manuals for them.
bearchopper
Re: JD 450
Post by bearchopper » Sun Sep 05, 2021 3:16 pm
Thank you for your help and info Bearchopper
Users browsing this forum: No registered users and 21 guests
