400G LONG TRACK
cantbeatadeere
400G LONG TRACK
Post by cantbeatadeere » Wed Jun 30, 2021 7:43 pm
Short story....I have a local painter lined up to make my 79 350c look a little prettier, bought the decals from Deere .....looking on the net and POW....... a two owner-never outside-well taken care of LOW HOUR(933) 91 400G LONG TRACK....all original. first owner used it 600 hrs and the second, well, the rest. He changed every fluid including the anti freeze and all filters 160 hrs ago, the engine oil 11 hrs before I got it, all Deere. it's gorgeous. like anything I have a couple very small things to make it perfect. they had only one battery(battery box is believe it or not..as new!!!) the tilt ram slight leak, the steering levers slightly off from each other when pulled and the blade needed a shim removed. the steps between the tracks are perfect shape. fresh grease along with a big ring of regular greasing's. the tool tray, under tray support(wooden O.E), all the brackets and the factory case along with the manual. drove 10 hrs round trip with the 3/4 ton Cummins and a 11,000 lb. tilt(little over loaded) running around 78 mph on the hywy, hubs and tires stayed cool even in the 89 deg heat. I am getting it tip top before I use it...............now, what to do with my mechanically PERFECT 2,320 hr 350c??? :D :D :D :D :D
1970- JD 2520, 1991- JD 400G long track, 2003- JD 4710, 2012- JD 1026R, 2014 Bobcat E42 long arm, 2016- 14ft dump trailer, 2017- 24ft 11,000lb hyd. tilt equipment trailer aaand 2018 ram 2500 Big Horn CUMMINS :D :D
77 Ford
Re: 400G LONG TRACK
Post by 77 Ford » Thu Jul 01, 2021 6:45 am
Congratulations on your find!!
I'd try and find someone who would appreciate the 350c and sell it. Nothing worse on a dozer than sitting forever, they are made to work. Now if you have sentimental attachment to it, I get that I'm close to the worlds worst on selling stuff.
JD- 450C track loader
Serial #208336T
Re: 400G LONG TRACK
Post by Lavoy » Thu Jul 01, 2021 8:45 am
That has always been one of my dream crawlers, good find, I'm jealous.
Al Swearengen
Re: 400G LONG TRACK
Post by Al Swearengen » Thu Jul 01, 2021 10:42 am
Aren't pictures of the new toy required? :D
'99 450G 6-Way
cantbeatadeere
Re: 400G LONG TRACK
Post by cantbeatadeere » Thu Jul 01, 2021 7:08 pm
This is my father (83 years old) who is a 33year Deere employee(retired in 97) when we were picking it up, and the drive home......perfect tong weight.. :D :D
cantbeatadeere
Re: 400G LONG TRACK
Post by cantbeatadeere » Thu Jul 01, 2021 8:03 pm
completely agree, setting is bad...there is probably not many 350's at all in this condition...I started at the transmission and worked my way out replacing any and all seals/gaskets, checking and adjusting end plays, replaced all couplers and ANYTHING remotely showing wear including reverser and hydraulic pumps(BOTH O.E.)...when I get something I make it absolutely top notch mechanically(and sometimes cosmetically) -- with how I operate and maintain I should never have to touch them again...so far so good.....
350C_Crawler
Re: 400G LONG TRACK
Post by 350C_Crawler » Tue Jul 13, 2021 8:18 am
Ya definitely found someone who will cherish it! Can’t tell ya how much I appreciate the machine and the hard work, time, and attention you gave her! Thank you again!!
77 Ford
Re: 400G LONG TRACK
Post by 77 Ford » Wed Jul 14, 2021 6:50 am
Welcome to the boards !
Serial #208336T
