Crown wheel pinion
EdPower
Crown wheel pinion
Post by EdPower » Mon Jun 28, 2021 4:24 pm
Hello all,Is it possible to get pinion and Crown wheel used or new ......for 350 crawler.
I think part number is At18842 . My pinion has a good chip out of one tooth ,
Could it be repaired ?
LeonardL
Re: Crown wheel pinion
Post by LeonardL » Tue Jun 29, 2021 7:48 am
Yes you can find them select used. I would check with Lavoy here on this sight first. Give him a call and see what he can do. Otherwise you will need to Google used John Deer Crawler parts to find a used parts dealer. There are several across the US and probably in Canada as well.
I never tried to have one repaired. I would think it would be rather hard and or expensive to get it done. My opinion, there may be others on here with a better answer than this. Good Luck!! :D
