440IC Negative ground 6v
Re: 440IC Negative ground 6v
Post by Stan Disbrow » Fri May 28, 2021 4:43 am
The main thing is the generator would then power discharge the battery. The regulator would be putting too much current into the field coils. These are relay regulators, and the overcurrent thru the relay contacts is probably....bad.
dtoots1
Post by dtoots1 » Fri May 28, 2021 7:46 am
stan,
so that would mean ..better check the battery? what would power drain do to the 6 volt battery?
Post by Stan Disbrow » Sat May 29, 2021 4:50 am
Won't hurt the battery. Might have hurt the regulator.
