350B and 350C
350B and 350C
Are there different things to look for visually to tell the difference in them to know your getting a C and not B.
JWB Contracting
Re: 350B and 350C
A few tells
- bolts to mount brake assemble on outside of a C series final drive, 3 bolts. I often buy based on picture, so look for this difference first
- under the seat, C has a 2 spool valve assembly on top of the rear end, a B series has steering boosters hooked to the steering clutch levers on the steering clutch cases. Same is true for a 450.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Re: 350B and 350C
Thanks JWB. Going to look at it tomorrow. Has 350C on it but I dont trust the sticker.
Re: 350B and 350C
The serial# should tell you as well.
