John Deere 420c reverser disassembly
Hi So I am working at dissassembling my late model reverser and I need some advice on how to get the spider out. I have all the pins out, However there has been water setting in it the last 2 years thus freezing it up. How would you recommend me to get it out with out damaging any thing? Thanks in advance
Re: John Deere 420c reverser disassembly
I have had good luck submerging piece like this under water (days-weeks). It has been 20 years since I took a reverser apart. And it was the older gear style. When I don’t want heat to change the structure of the metal, I will be patient and soak in water.
Best regards, Bruce
Best regards, Bruce
I will give that a shot. I kinda doubt that straight water will loosen the rust but I will try.
Water is hands down the best penetrant for rust other than maybe acid.
Ok Thank you I guess I learned something new today!
Users browsing this forum: No registered users and 167 guests
