JD 350 Crawler Loader steerng
dokey
Post by dokey » Sun Sep 27, 2020 9:52 am
The L/S power steering assist is not working. When I pull the R/S lever I see the ram moving out the backside of the housing. When I pull the L/S lever the ram coming out the back of the housing does not move
Re: JD 350 Crawler Loader steerng
Post by Jim B » Sun Sep 27, 2020 12:27 pm
dokey,
Your posts about your 350 belong on the Late Models Board. This board is for questions and announcements related to the site. It will likely be move over there when a moderator sees it.
To help get you correct answers and know what you have for resources a few questions. To clarify is this a straight 350, 350B, C, or D? Do you have the service/technical manual and the operator's manual for it? Did this happen all at once or has steering been getting weaker? Have you done any work to the steering system?
dokey
Post by dokey » Sun Sep 27, 2020 2:07 pm
It's a straight 350 and happened gradually. I checked the resevoir and it was empty. I added fluid , now both levers pulse when I pull them but the L/S still doesn't steer
Post by Jim B » Sun Sep 27, 2020 5:20 pm
Do you have manuals?
Users browsing this forum: No registered users and 220 guests
