1010 Radiators
1010 Radiators
Post by wwattson » Wed Jun 20, 2007 10:20 am
I don't need one quite yet but is there a source for 1010 radiators?
Post by Lavoy » Wed Jun 20, 2007 1:54 pm
None that I have ever found other than recoring you old one.
mailtrain
1010 radiator
Post by mailtrain » Wed Jun 20, 2007 6:18 pm
Hi Bill and Lavoy do you have a part number for the afore mentioned radiator. There is a neighbor who said he could get a radiator for anything,sounds to good but might be worth a try. He also rebuilds starters and gen/alts too. Dean
Post by wwattson » Wed Jun 20, 2007 6:33 pm
Well Dean, we can sure give it a shot. The Deere part number for the early 1010 radiator is an AT13096 (sub. for AT12918). The later models are an AT15331 (diesel without reverser), AT15327 (diesel with reverser), AT15328 (gas without reverser), and AT15330 (gas with reverser).
Gee, I can't understand why the things aren't common. It's not like Deere made 6 different radiators for the same basic crawler.
:wink:
mailtrain
1010 radiator
Post by mailtrain » Wed Jun 20, 2007 6:44 pm
Got the numbers Bill will find out and get the answer on for all to know. Thanks Dean
mailtrain
1010 radiator
Post by mailtrain » Tue Jun 26, 2007 8:32 pm
Spoke with the guy on the radiators,he will call and let me know. Couple of days or a week. I explained the reason for asking,he was unaware of not being able to get them. Dean
ROANOKEVA
Re: 1010 Radiators
Post by ROANOKEVA » Fri Jul 28, 2017 7:04 am
did anyone ever find out a source for these radiators ?
Re: 1010 Radiators
Post by Lavoy » Fri Jul 28, 2017 7:42 am
No, there are no aftermarket radiators available as long as I have been doing this.
whiteclipse16
Re: 1010 Radiators
Post by whiteclipse16 » Mon Jul 31, 2017 6:18 am
Lavoy, any reason why nobody is reproducing radiators for the "new generation" tractors? None for 1010, we can't ever find any for 2010's. Seems a little odd considering the popularity among collectors for all the new generation 10 series Deeres.
Ben
Re: 1010 Radiators
Post by Lavoy » Mon Jul 31, 2017 3:51 pm
1010 and 2010 have always been poor, both wheel and crawler. Seems Deere just forgot about them. The old joke is that Deere quit making parts for 1010/2010 the day the last one rolled off the assembly line.
I have been at this not quite 30 years, and even back then, 2 cylinder availability was better than the 1010/2010.
dtoots1
Re: 1010 Radiators
Post by dtoots1 » Mon Jul 31, 2017 5:43 pm
an aside to this gas versus diesel radiators.....friend of mine bent his top tank along with radiator...gas job.....actually run a cut block off a tree into the radiator ...no guard on it....we were able to get a diesel radiator and made it fit.....simply had to boost the hard nose up about 1/2 for clearance of the radiator filler/cap area to clear...hoses and hydraulic lines went thru lower pan for cooling too....(dozer 2010). been working fine for past year now...
dtoots1
