40C weight
gregjo1948
40C weight
Post by gregjo1948 » Thu Sep 10, 2020 12:18 pm
I have to pick up a JD 40C dozer and wondered what it will weigh. I'm guessing 6000/7000lbs. thanks, gregjo1948
Re: 40C weight
Post by Lavoy » Thu Sep 10, 2020 4:16 pm
Depends on blade, but 6,000 at the outside unless something is odd.
gregjo1948
Re: 40C weight
Post by gregjo1948 » Fri Sep 11, 2020 1:19 am
Thanks Lavoy. Are new undercarriage, steering clutch, engine rebuild, and etc. parts available for these machines? thanks, gregjo1948
Re: 40C weight
Post by Lavoy » Fri Sep 11, 2020 7:23 am
Undercarriage is very limited as far as new. But I can rebush rails and have some core rails if yours are too bad to bush. Used parts are normally fairly available.
Engine parts are no issue, electrical, wiring harness, gauges, many other small parts are available, some in stock.
Users browsing this forum: No registered users and 180 guests
