40C weight
40C weight
I have to pick up a JD 40C dozer and wondered what it will weigh. I'm guessing 6000/7000lbs. thanks, gregjo1948
Re: 40C weight
Depends on blade, but 6,000 at the outside unless something is odd.
Re: 40C weight
Thanks Lavoy. Are new undercarriage, steering clutch, engine rebuild, and etc. parts available for these machines? thanks, gregjo1948
Re: 40C weight
Undercarriage is very limited as far as new. But I can rebush rails and have some core rails if yours are too bad to bush. Used parts are normally fairly available.
Engine parts are no issue, electrical, wiring harness, gauges, many other small parts are available, some in stock.
Users browsing this forum: No registered users and 206 guests
