420 radiator
420 radiator
hi guys , i have my radiator out of my crawler , im wondering if there is a product or just soap and water i can use to clean it out or wait til i get it back on the tractor and just do a full flush on it , it has no thermostat ( thermosiphon ) if that matters , thanks all .
Re: 420 radiator
According to Ron O'Neill, the Tractor Doctor, in the August issue of Green Magazine, you can use muriatic acid in radiators and even in engines using thermo-siphon cooling.
Re: 420 radiator
I thought all 420s had water pumps and thermostats??
Re: 420 radiator
They do, we are thinking his crawler has had a 40 engine installed.
Re: 420 radiator
I take my nasty radiators to a radiator repair shop. They'll soak and flush or replace the core.
- Paul Buhler
Re: 420 radiator
I’ll second Greg. It’s a pain to deal with a poorly working or leaking radiator. Getting one repaired and pressure tested means that you’ll have one less worry. If you reinstall yours, boil it with acid, and a leak develops, you’ll be back at square one. Good luck with what ever you decide.
Users browsing this forum: No registered users and 146 guests
