pic of pto shaft
pic of pto shaft
Well my quest to find a pto shaft for my JD350 has turned up nothing. I’m referring to the shaft that comes out the back of the transmission through the 3 bolt flange. Would anybody have a good picture of one, it would help explain to the machine shop how to build one?
Re: pic of pto shaft
Hello renogang,
This is a link to the Deere parts book with the shaft and cast pieces. This is the best I can do .
https://partscatalog.deere.com/jdrc/sid ... gId/172102
Best wishes,
Bruce
Best wishes,
Bruce
yeah thanks i have that one, was hoping for an actual picture showing the two snap ring grooves, bearing and seal mating surfaces, etc...
JWB Contracting
Are you looking for a PTO shaft or a winch drive shaft. Winch drive shafts should be readily available.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
I would take either, have asked Lavoy and about 10 other salvage places, no luck. Do you have a source?
Have you tried this fellow in Vermont? He often advertises winches and 350/450 parts on Craigslists around New England.
https://nh.craigslist.org/hvo/d/johnson ... 30597.html
thanks for the tip, i called once already, will see if he answers later
I got a winch shaft from your tip! Thanks a bunch!
Randy
Randy
Users browsing this forum: No registered users and 75 guests
