jd440ic distributor timing
well folks..am having a question on my timing...it seems that my points are opening just after it goes past the wire. i have not moved the distributor since i bought it and has been running ok, points gap is at 22 thousandths and is open about 3/4 inch past the wire on the outside circumference of distributor.....i assume that i should turn the distributor to that area and see if it helps tho with my hearing am not sure of results. i assume the points would then open at the wire as i believe it is supposed to. do not have timing light.
Re: jd440ic distributor timing
Set the flywheel to spark, rotate the dist til the points just start to open.
Thanks Lavoy,
must have been real close as only had to move it a hair.
seems to be o.k. now...
will see later how she does
Users browsing this forum: No registered users and 202 guests
