450C Coming Home.
Claus
450C Coming Home.
Post by Claus » Sun Oct 20, 2019 3:41 pm
I'm pretty stoked my 450C is coming home tomorrow. I bought it 2 years ago and it broke very shortly after. The castle nut on the end of the pinion shaft had broken and a bearing was out in the front gearbox, hard to say which happened first but it was a mess. My Uncle donated His time and shop, can't thank hime enough. Replaced the clutch, rear main seal, throw out bearing, pilot bearing, reverser pump, a few gears, ring and pinion. many, many other bearing, races, seals, etc. Put on K&M seat cushion, Auto Meter Gauges, new stack and Centri precleaner, alternator and battery and lots of small stuff. New injectors and pump rebuild planned for next year, little hard starting right now.
DrLoch
Re: 450C Coming Home.
Post by DrLoch » Mon Oct 21, 2019 6:52 am
Nice machine. I have one just like it although not near as pretty. It needs some work now as well.
450C Track Loader
291457T
77 Ford
Post by 77 Ford » Mon Oct 21, 2019 7:27 am
Nice looking machine.
On the trans temperature gauge did you go with mechanical or electrical sender? If electrical what sending unit did you use?
JD- 450C track loader
Serial #208336T
Users browsing this forum: No registered users and 31 guests
