Hi, I 'm rebuilding my two cylinders lifts of my no.1000 tool carrier on my 40c. My question is, normaly should the piston have one or two O-ring on each sides? Mine have two but on the part diagram I can just see one O-ring.
Thank you
no.1000 cylinder lift question
John Deere 40c 1954
Re: no.1000 cylinder lift question
There should be an o-ring and a backup on either side. On the inside end I have found that there is enough room to put 2 backups in. Don't know it is critical, but for a couple bucks can't hurt. Make sure to index the shaft correctly when reinstalling.
My pistons have two grooves to put two o-rings...
John Deere 40c 1954
Sorry, I screwed up, I was thinking shaft, not pistons. I have never seen one with two O-rings, but maybe the later pistons had them. If there are two full grooves, I would put an o=ring in each one.
Laovy
Laovy
I don't have enough place to put two backup both sides if the o-ring, just for one so witch side is the best to put one backup?
John Deere 40c 1954
In this case, doesn't really matter, you have pressure both ways.
Users browsing this forum: Hurlbutt and 227 guests
