hydraulic
tinkerer
hydraulic
Post by tinkerer » Wed Apr 13, 2005 5:11 pm
What mite be the problem with my 440ci loader?I was digging and the bucket just stoped no up no curl no nothing . I dont see any leaking lines,a little low on hydfluid. Could it be that the pump just went or the pump drive?.
Post by Lavoy » Wed Apr 13, 2005 8:26 pm
Most likely the pump drive coupler, possibly something internal, but would check the drive first.
tinkerer
Post by tinkerer » Thu Apr 14, 2005 4:11 am
I will check the drive coupler , if it is bad ,were doI find another,do you sell them and how much.?
Thank you
Post by Lavoy » Thu Apr 14, 2005 10:26 am
They are hard to come by, I have been planning on making new couplers and the splined shaft, but just have not had time. If yours is bad, let me know, maybe I can get one done quickly.
tinkerer
Post by tinkerer » Thu Apr 14, 2005 6:20 pm
the splines on the pump input shaft are toast and so are the splines in the coupler and the stubshaft. We emailed the pump manufacturer,to see if pump parts are still available, the pump is in good shape, but not it input shaft.This weekend I will go boneyard shopping,I want to see if I can scroung some of the parts(trade,barrow, or dicker) and check on the 3 clark airborne dozers I looked last year. If I cant find the coulper or the stub shaft can you make them and how much?
Post by Lavoy » Thu Apr 14, 2005 7:37 pm
Can't give a fast answer, it would take some research to see if I can even get the correct stuff to even begin machining.
As far as I know, there are no parts available for the pump.
tinkerer
Post by tinkerer » Thu Apr 14, 2005 8:54 pm
tHANKS I will be in touch
Users browsing this forum: Google Adsense [Bot] and 42 guests
