Case 580C
77 Ford
Case 580C
Post by 77 Ford » Thu Jun 13, 2019 9:10 am
The machine has a combination of pins that grease and bushing with zerts. However it has 4 pins that have no way to grease them. No hole thru the pins, no bushing zerts nothing. Is this normal or has someone switched the pins out? They look factory but I can't imagine having a non grease joint.
JD- 450C track loader
Serial #208336T
Re: Case 580C
Post by Jim B » Thu Jun 13, 2019 12:33 pm
It does seem odd. Knowing the location/which pins might help.
77 Ford
Re: Case 580C
Post by 77 Ford » Fri Jun 14, 2019 7:06 am
Both lower pins on the front bucket and 2 of the pins that connect the rear digging bucket.
Serial #208336T
Re: Case 580C
Post by Jim B » Fri Jun 14, 2019 7:23 am
That is what is shown in the on line parts books. My thoughts are they figured the wear on those particular ones would be more if there was grease to hold grit in the joints then if they were left dry.
If you don't have this here's a link to the on line Case Construction Equipment parts book for the 580C.
https://partstore.casece.com/us/parts-s ... c::mr49912
77 Ford
Re: Case 580C
Post by 77 Ford » Tue Jun 18, 2019 11:47 am
I think you are right. I think there is supposed to be oil bronze bushings in there and they have just dried up. I'll change the bushing and see how it goes.
Good eye, and thank you for the help.
Serial #208336T
