Oil cooler leak on 350B
cjman1977
Post by cjman1977 » Fri Apr 26, 2019 2:25 pm
The oil cooler is leaking between the cooler and the block. Is there a special gasket or is it just an O ring that seals it? In the parts manual it calls it packing. Just trying to get some info or some parts BEFORE I take it apart. Anyone got experience in this matter?
Bennett
JD 350B w/ 4 in1
JD 1025R Sub Compact
CAT 259D3 high flow with Mastodon mulcher head; CAT BRX 318 bush hog
Cat 304 Mini Ex with Bushmaster Brush Cutter and 28" Torrent mulcher
Soilmover Dirt Pan
Re: Oil cooler leak on 350B
Post by Jim B » Fri Apr 26, 2019 4:39 pm
I believe you are referring to the engine oil cooler the engine oil filter mounts on. If so the parts manual calls the seal between it and the block a washer, part number R70956. It might be the same as the oil filter gasket but, I would get it, by the part number, from JD rather than risk an engine with the wrong material or a bad fit. You can use the on line parts manual at https://jdparts.deere.com/servlet/com.d ... anguage=19 to check it out.
Users browsing this forum: Google [Bot] and 9 guests
