My crankshaft pulley is lined with stainless steel where it goes through the timing cover and seal. It has grooves in it that look like its made that way. Is it suppose to be that way or are they worn in it? If so what can be done about the grooves?
Thanks,
Lew
550 Crankshaft Pulley 4-276 engine
JD 550 dozer, Case 1845c skid steer, Case IH 5140 tractor, Case IH 5130 tractor, Case IH 80 tractor, Kioti 3054 tractor
Re: 550 Crankshaft Pulley 4-276 engine
you most likely have a wear sleeve spedi sleeve on your crank pulley they are replaceable heat the sleeve that will expand it and replace available
at some auto stores or motion industries
Users browsing this forum: No registered users and 212 guests
