JD 550c transmission oil loss/transfer
Hyd.jack
Post by Hyd.jack » Wed Sep 12, 2018 8:39 pm
After replacing my rt. side final drive axle I was using my drive sprocket to "load" my track back on and the drive stopped turning....found no oil on transmission dip stick...poured 3 gallons of oil in and drive started turning again, for about 2mins. The trans. oil is transferring to the brake/clutch housing (housing between rear of tranny and final drive) the oil gushes out of the fill plug of that housing! Has anyone experienced this? All was fine before the broken axle. If so what was the cure? Thanks!
DrLoch
Re: JD 550c transmission oil loss/transfer
Post by DrLoch » Thu Sep 13, 2018 6:17 am
A 450C does move/transfer oil to the finals and back to the main housing so my guess is that a 550C does the same thing. Your manual would explain all that.
450C Track Loader
291457T
Users browsing this forum: No registered users and 479 guests
