Does fuel filter need to be full
nicoz
Post by nicoz » Sat Aug 11, 2018 9:46 am
I am having issues with my machine randomly stalling out but restarting without a problem. One thing I noticed is that the primary fuel filter doesn't fill completely (stays about 1/3 full. I seem to recall that when I replaced it and primed it a while ago, it filled and then came out the bleed screw. I tried bleeding it again and it flows fine out the bleed screw but doesn't fill the filter completely. Am I wrong to assume it needs to remain full always or am. I just remembering incorrectly?
Current Machine: 1981 John Deere 450C w/ 9300 Backhoe
Rincon
Re: Does fuel filter need to be full
Post by Rincon » Sat Aug 11, 2018 10:56 am
My 450C C filter is always full
Post by Stan Disbrow » Sat Aug 11, 2018 1:38 pm
Needs to be full. Time to bleed it again. If it keeps happening, you need to find the source of the air leak.
gregjo1948
Post by gregjo1948 » Sun Aug 12, 2018 5:24 am
Does a 450 have a fuel lift pump to put fuel to the filters?
Rincon
Post by Rincon » Sun Aug 12, 2018 8:32 am
Yes , fuel injector lift pump.
DrLoch
Post by DrLoch » Sun Aug 12, 2018 9:44 am
Mine is also always full, Also check all the usual things;
Vent hole in fill cap is open.
450C Track Loader
291457T
gregjo1948
Post by gregjo1948 » Sun Aug 12, 2018 10:22 am
Perhaps the lift pump is weak or drawing air and not supplying enough fuel to keep the filter full.
B Town
Post by B Town » Sun Aug 12, 2018 11:43 am
Check engine oil for diesel contamination. Those pumps have an o ring on the engine side. They leak fuel into the engine oil; therefore, I believe it is possible to develop air in the fuel system. This type of problem needs to be caught early. Stan can give us an education on the properties of diesel mixed with oil.
Post by Stan Disbrow » Sun Aug 12, 2018 4:40 pm
Yeah, that'd be bad. Diesel thins the oil and it flies out between the rod bearing and the crank and....no more cushion. Not long after, beat up crank journal. After that, the best hope is the thing quits before the main bearings get it as well.
nicoz
Post by nicoz » Fri Jan 31, 2020 5:56 pm
Sorry for my tardy reply. The weather here has been awful and now it's warmed up enough to try some stuff. Turns out there was a bunch of algae or other shit in the tank. The screen for the outlet was plugged up. Couldn't get that dang screen out but ended up blowing air through and cleaning her out. Runs better than ever. Thanks all for the replies.
Users browsing this forum: NevadaKid and 181 guests
