Just finished redoing the steering clutch on my 350 and got some work out of it last weekend. Thanks to this site for the great info on steering clutches! I blew the loader bucket hydraulic hose. I couldnt reach the back end fitting to disconnect it and didn't have a crowfoot.
It's parked in the woods 3 hours away, and I need to get a new hose made up.
Does anyone know length and fitting type for the loader hoses?
Thanks,
Mike
Need hose specs for JD350 loader hydraulic hose
Re: Need hose specs for JD350 loader hydraulic hose
Best I can say at present would be to find the part number for the hose you need and check with your JD dealer. If they don't have it, or can't make one, they may be able to tell you the type of ends and length. Some of the hose info shows up on the parts catalog info on line but the ones I looked at refer to a type 10 end. Maybe some one here has the info to cross reference the JD end types, but that needs to be translated to pipe, JIC, O-ring, etc. for a hose shop to make one.
Here are the hoses and connections I bought when I did mine (450C), maybe it will help.
Here are the quantities, sizes and lengths of hoses I need
(2) Bucket Rollback 3/4" Hose 3/4" Male NPTF, Rigid 3/4" Male Straight Thread O-Ring, Rigid 24 1/4" OAL
(2) Bucket Dump 3/4" Hose 3/4" Male NPTF, Rigid 3/4" Male Straight Thread O-Ring, Rigid 22" OAL
(3) Bucket @ Boom Connection 3/4" Hose 3/4" Male NPTF, Rigid 3/4" Male Straight Thread O-Ring ,Rigid 28 3/4" OAL
(4) Boom Cylinders 3/4" Hose 3/4" Male NPTF, Rigid 3/4" Male Straight Thread O-Ring, Rigid 21" OAL
System pressure is ~ 2250
450C Track Loader
291457T
291457T
