Jd 350 direction reverser has no power
JSmith
Post by JSmith » Tue May 08, 2018 4:55 pm
Before I had too thin a fluid, so I put in some hydraulic oil in and it worked fine. Now it's warmer and it drives fine for a minute but once it warms up it loses all it's power and doesn't turn. Should I be using summer hydraulic oil if there's such a thing. If you check the fluid it's quite warm and seems pretty thin. Thanks
Re: Jd 350 direction reverser has no power
Post by Lavoy » Wed May 09, 2018 8:11 am
Reverser is multi trans fluid, not hyd fluid, that might be part of the problem. Straight hyd oil will wreck something sooner or later. Doubt viscosity is your problem, possibly pump issue.
JSmith
Post by JSmith » Wed May 09, 2018 3:00 pm
I used tdh. I think I will try the oil that John Deere recommends. If it is the pump I would like to limp it through the summer and rebuild it over the winter. Would that cause any excessive damage
Post by Lavoy » Fri May 11, 2018 7:53 am
If the clutches are slipping, you will burn them up.
Users browsing this forum: No registered users and 213 guests
