Turns out the water pump stamped part number corresponds to an engine year and application.
Fits any year 350 350B 350C Dozer or Loader per Deere industrial parts.
Took a look through the FAQ board and didn’t anything on this subject. Found a number on the water pump flange T23629T Serial number or water pump part number ?
I have a JD350 - 152CI/42HP/3 cyl gas engine pulled. Is there a serial number on the engine and if so - where? The crawler frame already went to scrapyard, so I can’t do it that way. I’d hate to scrub the engine down looking for a serial number if I can narrow the area down.
Serial # on JD350 engine - update
Atnsolutions
Re: Serial # on JD350 engine - update
You're probably long past this issue but my service manual shows the engine sn to be slightly left of the eng oil dipstick.
152 CID is a Diesel. The gas was 135 CID, and lower HP. But, I don't see a HP figure for the gas in my manuals, just for the Diesel. The Specifications pages are a bit misleading, only covering the Diesel as far as HP and torque figures.
Users browsing this forum: No registered users and 9 guests
