The tensioner shaft is seized into the spring I wedged the block of wood under it and sprayed it down with that aerokroil stuff at $30 a can it better work! Tried hitting the cylinder too. No luck!
Oh and yes my tensioner spring is broken as well!
Morning Will,Will1020 wrote: ↑Fri Apr 06, 2018 1:30 amhttp://www.directupload.net/file/d/5049 ... o6_jpg.htm
Ok last pic for today. Time for sleep. This one is looking straight down at the rear of the frame work. Its where the rear frame attached to the cross bar. You see how the housing is worn on the outside?!?! What the heck. I guess the chain was hitting it at one point? That is the last rear roller at the bottom btw... Any thoughts?
"You'd think this type of exploring and reserecting would get old..." For some of us it never does.You started in 94 I started 20 years earlier and some members here started 20 years earlier than me.It is definitely a passion and not "work".Will1020 wrote: ↑Sun Apr 08, 2018 6:58 pmEverything off. http://www.directupload.net/file/d/5052 ... 5n_jpg.htm
4hoses under step
http://www.directupload.net/file/d/5052 ... 8l_jpg.htm
4 lines under seat frame
http://www.directupload.net/file/d/5052 ... g9_jpg.htm
Removed sub assembly
http://www.directupload.net/file/d/5052 ... 6n_jpg.htm
I worked on getting my air compressor and Welder up and running. I can already tell there's going to be alot of welding holes shut then tapping them back open. I did however get the right saddle bag/ hydraulic reservoir/ control valve off today. It was pretty straight forward. First thing I did was remove the plate where the hour meter is located. Mine was conviently unhooked with 6000 on it. I have no idea if that's alot or not. I then drained the reservoir from the drain plug located to the back side of the crawler it's magnetic and clean!. Then had to remove two bolts holding right step/threshold down. Then removed seat frame assembly. After that's out of the way you can get access to the hydraulic lines. You'll need a 1 1/8 wrench and I believe 1 1/4 wrench. Take off the 4 hydro lines at the step area then under seat frame. Don't worry to much on getting them mixed up the ones under seat are all different lengths and the ones under the step are all rigid and don't move much. I did notice alot of play in the hydraulic handle pivot area. Lol found the ball joint assembly that the left right motion on the lever controls to be completely worn and of coarse....wait for it...... Welded yet again. Now that little ball joint link isn't but twenty bucks. Why do people do this kinda hack work. So after all the hydraulic lines unhooked I unbolted the nine bolts that held the entire box assembly to the crawler. Lifted it off with the old Ford and lots of access room now.... I don't know why but I'm actually enjoying this. You know Ive been a Auto tech my whole life. I started in the field in 94. You'd think this type of exploring and reserecting would get old... I pretty sure it's something in the blood...
BH attachment is pretty basic: look for worn pins and bushings,cracks,welds,etc in the stick(dipper to some) and boom.Cylinder condition is an unknown as you cannot get pressure to them. Looks like the seller slathered grease on the rams and you can wipe that off to look for missing chrome or pitting.Will1020 wrote: ↑Sun Apr 08, 2018 4:33 pmhttps://york.craigslist.org/hvo/d/john- ... 43061.html
Ironically this came up near me. I need to figure out if my 450 is going to survive then look at this. I'd have to sell my old Ford tractor to buy it though. Any knowledge on these? Worth that price? The fresh paint worries me
Users browsing this forum: No registered users and 201 guests
